I have a 30,000 gallon gunite inground pool that had some pool chemistry issues that I typically don't have. The past few days I had to shock the pool, raise the alkalinity, lower the pH, add calcium, and add chlorine stabilizer. I had my water tested again when it was almost clear and had 3300 ppb phosphates which they told me was very high. I added 3L of the Leslie's Nophos 24 hours ago and the pool turned milky white. The label says non cloudy formula so I am concerned this really screwed up my pool.
FC 15 ppm TC 15 ppm pH 7.4 TA 96 ppm CH 256 ppm CYA 35 ppm Phosphates 3300 ppb Iron 0.2 ppm Copper 0.3 TDS 1650
Any ideas? This year has been pretty expensive so far. I have a sand filter. After 24 hours the pool is unchanged still milky white, can't see pool robot at bottom. I added clarifier 4 hours ago nothing changed so far.
