Moved from here.
This is the 52ZY24-50 impeller motor in mine that I suspect this the reason why my S200 is not working. Goes forward, backward, then stops. The impeller motor looks fine in general, it will turn but the bearings are "stiff" as best I can describe them - not seized but by no means free spinning, but on the bench when I put power in the unit, the drive motor works, but the impeller motor does not start spinning unless I tap the motor shaft, then it runs.
I would buy a new impeller motor if anyone knows where one can be had, or I can do the rest of the tear down and see if new bearings help get it started.
If anyone has ideas, LMK.
