My ~2016 MasterTemp 400 suddenly stopped igniting. Normal no ignition, I smell gas, hear click, etc. No puff of heat, no sound of ignition.
It wasn't getting hot anywhere around the igniter, as measured with an infrared thermometer, so I assumed it was the igniter and ordered a new one without checking. The existing one looked and measured fine when I pulled it out but I replaced it anyway.
When that didn't make a difference, I measured the voltage going to the igniter. After connecting a multimeter, upon reapplying power, there was an idle ~16VAC on the igniter leads. When it kicked on, I only measure ~76VAC to the igniter.
The troubleshooting guide suggested replacing the ignition control module, so I got a new Fenwal and replaced that, which has also made no difference, still only getting 76V to the igniter leads.
I don't see any evidence of damage or wear to the wiring inside the heater. Any ideas before I give up and call Pentair?
240V supply.
Thanks
G
240V supply.
Thanks
G
