Ok, after opening the pool a week ago, it’s making progress. Just want to make sure I’m on the right track. The pool is slowly turning blue and clearing up. I can almost see the bottom in the deep end at this point. I just ran a test with the following results:
Pool specs:
In ground vinyl
35,000 gallons
Filter: Hayward Sand filter Pro Series
Pump: Pentair IntelliFlo
SWG: Turned off (water temp)
FC: 1.2
PH: 7.2
TA: 80
CH: 80
CYA: 30
TC: 5.9
Pool math dictates @6 gallons & 1 quart of 6% bleach (all 10% is out of stock here in Iowa). Anything else needed here? Thanks as always!
Pool specs:
In ground vinyl
35,000 gallons
FC: 1.2
PH: 7.2
TA: 80
CH: 80
CYA: 30
TC: 5.9
