- Nov 28, 2020
- 51
- Fiberglass
- Astral Viron eQuilibrium EQ25
Hi all. Hoping for some clarity (of my water too!) I recently completed a SLAM with no OCLT and crystal clear water. After only a week or so, FC was staying above 7 and then started to go cloudy again. Also noticed white crusty flakes in the pool. Quite a lot. I had a look on the SWG plates and couldn’t see any obvious build up blowing off.
Just tested water and TA has gone way higher than it’s ever been at 110.
So my question is, can the high TA be contributing to the cloudiness?
Is the cloudiness actually algae anyway so do I have to get back to SLAM?
Or is the cloudiness other stuff from the flakes that will go if I lower TA?
Other words. TA is high, SLAM only recently successfully completed but water cloudy and still no OCLT. Should I SLAM or just get the TA back down?
I think you can see my pool school data???
Thanks!
Thanks!
