Low water level spa
Aelmore11
2
Florida
Our spa water lowers when pump is off. Check valve appears closed and working. Any trouble shooting would be appreciated as pool maintenanceimage.jpg is new to me.
Debris can get through a filter at times, especially after a cleaning. It can get caught in the flap in that check valve that is closest to the ground and the pool/spa return valve. Also, be sure the suction valve is completely off the the spa side.
A,
Make sure you are looking at the right check valve. It is the one in the spa return line, not the one next to your heater.
It is almost always the cause when the spa drains back into the pool when the pump is off.
A,
We replaced the check valve. No luck. The check valve on the spa return appears to stay closed whether the pump is on or off. Is that normal.
A,
The check valve on the spa return line allows water to flow to the spa when in the spa mode. It could also allow a little water to go the spa in the pool mode if you have a spillover spa. It is there to prevent any water from the spa to flow backwards through the check valve and then back in the pool.
As a test, you can take the manual valve that is between the Pool Return label and the Spa return label and shut off the pipe labeled Spa return. This should shut off your spillover. If the spa does not drain down with the Spa return pipe shut off, you know the problem has to be the check valve.
As a side note you much have a lot of water spilling over into your pool. Generally, this valve is set about 90% pool return open and only 10% spa return open.
