Hi everyone
My l Leisure Pool ultimate 35 fiberglass with a built in spa. It is leaking and I’ve narrowed down it is at the spa after shutting pump off for 3 days , cover closed, spa plumbing isolated, and measured water level.
Result
1. Pool water no drop
2. Spa water dropped 6cm (2.3”)
3. Pump off, cover on, spa suction valve closed. Spa return valve closed
I highly suspect this has to do with what I did when I closed my pool this last winter:
1. I used duck plug w/o telflon and screwed in too tight. When I tried to unscrewed it to add teflon, I unscrewed the actual return wall fitting itself (see photo; the one with expansion black plug).
2. I was able to screw it back in with a channel lock but from what I’ve heard, you’re not suppose to be able to unscrew the wall fitting itself.
3. The spa was filled to the top at closing. The suspected return fitting is at the bottom. When I opened the pool this year, the water didn’t decline to the leak location which is puzzling.
What I’m doing next
1. I plug the suspected return with an expansion plug and marked the water level again to see if it lowers in 24 hours.
Meanwhile, any advice if this can be fixed without having to dig up the ground? Any advice for next step? I don’t want to accidentally do something to make it worse.
Result
What I’m doing next
