So i've been having issues with my SWG. Starting off with last year (my first year in this home) everything worked fine. ran swg at around 60% and would maintain 5-7 ppm FC. this year after completing the opening SLAM and passing OCLT i found myself needing to increase the output to 80-90% on 8 hour (11am-5pm, 10pm-12am) to maintain even 5ppm. figured since the cell was probably 6-7 years old (pool was built in 2011) that maybe the cell was shot. i cleaned it with MA as a last ditch effort but it just wasn't producing enough chlorine given the output level. last year if i cranked the cell up after a pool party and ran the pump overnight i'd easily be at 10ppm.
I ended up biting the bullet and purchased a brand new cell (https://www.amazon.com/gp/product/B06XTDJW9N/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1). installed it, and i am having the same symptoms. i decided i'd just set it to 100% and see what happens, ran it that way for 2 full 8 hour cycles and tested it again and had 3ppm chlorine this morning. so basically after 16 hours of run time in 2 days at 100% i'm at 3ppm chlorine which makes no sense. Relevant numbers below. I called hayward and they asked me my phosphate level, which i dont test for, and they claimed that could be whats eating up my chlorine. Could it be that i have some algae and i don't realize it and that's whats eating up my chlorine? I would think even if i had some kind of algae growth, it wouldn't be enough to basically consume the entire amount of chlorine generated by 8 hours a day of 100% cell runtime. i'm at a loss and could really use some advice. Thanks!
FC 3
CC 0
CYA - 75
TA 60
PH 7.2
Borates 50
Salt - 3400
Temp 79
voltage (generating) 23.5
current 5.39
output 100%
Salt 3400
AL - 0
Version 1.58
cell - t15
Power/Generating are both green with no other lights flashing etc. i can hear the relay kick on when it starts generating.
FC 3
CC 0
CYA - 75
TA 60
PH 7.2
Borates 50
Salt - 3400
Temp 79
current 5.39
output 100%
Salt 3400
AL - 0
Version 1.58
cell - t15
