Hi. Has anyone see this before? This is my 3rd pool and first with a sand filter. When the system isn't running, late at night it make a horrible noise that sounds like someone is blowing into a conch shell. It a really loud sound of air escaping that is deep and reverberating and squeals at the end. There is air in the system when it is running coming from the screw seal at the pressure side of the pump that I just removed and I am repairing. As a result there are bubbles in the jets and more than a dime's size worth of air in the top of the pump window; perhaps 3/4 of the window shows a bubble. Does a leak on the pressure side cause some kind of pressure build up that finally releases with a horrible screech later after it's been not running for a while? Never seen this before and I've fixed several air leaks.
