- Apr 26, 2023
- 29
- Vinyl
- Hayward Aqua Rite (T-9)
I'm looking to add some type of remote automation to my current setup.
We built out pool last year and didn't think automation was worth the $2k-$3k mentioned during contract build. However, we have only an on/off switch for out single speed pump.
Out setup is: 10K gal, IG vinyl, 1HP Pentair SuperFlo pump, Hayward 210t sand filter, AquaRite 900 T925 SWG, Raypak 156ng heater, Tiger Shark QC, Auto Cover
Ideally we'd love a full automation retro-fit that could work with our pump, swg and heat, but wouldn't be opposed to pump and heat (Assuming SWG settings won't need adjusted much outside of tweaking when testing and after pool parties to increase). I'd like to keep the solution price below $750 if possible depending on the features.
I've been reading through the forums and other sites and haven't found a solution that seems to fit our needs.
The two things that i have found are the Pentair IntelliConnect: IntelliConnect® Pool Control System - TradeGrade or just a very plain and simple WiFi pool timer: https://www.amazon.com/dp/B09P5YFD7...olid=1D1XDLSGPRAE2&psc=1&ref_=lv_ov_lig_dp_it
at the very least, i need some type of timer for the pump so i don't have to manually turn on/off each day (i've been leaving it run 24hrs since they opened our pool last week).
If the only viable solution would be to have a WiFi timer for the pump, would it be possible to control the temp outside of setting a desired temp and the heater will run when the pump is on if it's below that temp?
Thanks for helping a new pool owner
-Philip
-Philip
