Looking for best positioning for return jets
Bob2010
Active member
May 30, 2023
27
Ontario
New pool owner - first season,
trying to figure out how to position my return jets. 16X32 sports pool with 2 main drains, 1 skimmer and 2 returns. Outlined below roughly for positioning. Skimmer slightly more on steps side as opposed to half way. Two drains in the middle of the pool as deepest section.
___________________S___________
| ..........................D.............................|
| ............................................. ........... | <------ Concrete steps (3 total), full width on this side
R .........................D............................ |
________________________R_______
What direction would you suggest I angle the returns for water flow? Clockwise vs counter clockwise. Should I just accept dead zone for the steps and be vigilant about manually brushing every few days? Should the return jets be pointed downwards? Currently they are angled in a way that I can see some ripples on the top of the water surface from the jets.
thanks
Wind direction means more than anything else. Use the returns to enhance the wind direction to the skimmer. The Drains should be mostly turned off.
I have a separate skimmer and main drain line that goes to a 3 way jandy valve and then to my pump.
If I’m understanding correctly I should point the off part (currently not facing any of the 3 pipes) towards the main drain (maybe around 50%?). Any problems this could cause to the valve or plumbing by doing that?
I would point the OFF to nearly shut off the main drain. No issues to the valve or plumbing.
