Hey everyone,
New to owning a pool. Just had it installed close to a month ago. I've been following all the steps here to maintain the correct chemistry and feel that I have it pretty dialed in.
So on to my next worry, Closing! Here in Indiana, we do get below freezing temps. Sometimes it could be a couple of days, weeks, or sometimes a month long. Our pool has a heat pump installed with a freeze protect. We also have a automatic pool cover. My question is, can we keep the pool open during the winter here? From reading it seems as long as I have the pump running (high) and the heat pump running, we could keep it open. However, I'm questing the heat pump as if we run into a month long below freezing temp, is it enough to keep the water from freezing? Do we take the chance of possiblity freezing and busting our pipes or just close it.
Closing it would consist of what? We have 2 skimmers, 2 return jets and a main drain. I'm not sure on what needs to be done. This is as much as confusing as it was when trying to figure out the chemistry thing.
Can someone give me a definite yes that we can keep it open during the winter (which seems easier), then closing it?
Thanks for the help,
Jake
Jake
