- May 3, 2014
- 62,780
- Fiberglass
- Pentair Intellichlor IC-40
Ok I think I have a serious calcium hardness problem. I have been noticing it is taking more and more bleach and muriatic acid to keep things at the right levels. There is now what looks like brown scale/mineral deposits appearing and they wont brush off.
The other day after adding some water (we lose about a couple inches a week from the heat) I tested my water and the CH was almost 1000. The tap water around here is insanely hard I guess.
So how am I supposed to lower the CH? I read that the 'pour in' solutions don't work, and the only way is to refill with fresh water, which I COULD do (since it evaporates so fast), but I need a way to lower the CH in my TAP WATER now too..
Your water source in most of southern Nevada is the Colorado River. It's natural CH is about 250ppm and TA 140 ppm.
The only way to reduce CH in pool water is to replace it with water with less CH or hire a reverse osmosis service that comes to your pool and runs the pool water through a RO unit. They still will need about 1/4 to 1/3 new water and cost ~$750 to $1000.
If you have a water softener that you can pipe to use as make up water (used due to loss from evaporation) you can stem the cycle described above.
Do NOT buy any internet potions that claim the remove calcium. They do not. Some tie it up for a while so they do not scale but none remove the calcium from the water.
