- May 23, 2015
- 25,728
- Plaster
- Pentair Intellichlor IC-60
The kit is basically a series of different chemicals for diagnosing stains. They are dry acids and dichlor powder. The purpose is to see which chemical has the greatest impact on the stain. Dichlor removes organic stains. Ascorbic acid removes iron. Sodium bisulfate removes calcium scale and sulfamic acid is good at removing copper and cobalt stains. Based on which one or combination of chemicals work, Jack’s Magic then has a program that you can treat the entire pool with.
If the stains are only in the deep end, you’ll have to make up something like a poultice using a nylon to hold the powder and then use your pool skimmer pole to hold it against the stain. It’s much easier to do these determinations in the shallow end and when the water is warmer. You may want to simply wait until spring when the water has warmed up enough. I doubt the problem will get significantly worse.
