Liquid Chlorine Gone From Shelves...
LGLDSR73
89
Boston
I've been using Pool Essentials Liquid Chlorine (12%) but it's all be disappeared. I assume I can use off the shelf Clorox Bleach, non-scented? I believe it's 10%. Any keywords to avoid such as 'Now with Extra Whiteners", etc? Should I expect any difference in impact on CYA, pH, T/A from what I've been using?
As always, thanks.
Skip
Lilypad
246
Plano, Texas
Yes, that works fine. Plain, ol' bleach. Walmart has their Pool Essentials as a seasonal item. You can find liquid chlorine at Lowes. It's their Kemtek brand.
BowserB
363
Katy, Texas
Don't know about Boston, but Houston area Leslie's has four gallon containers in a box. 12.5% for $15.99. That's the cheapest per oz of chlorine I've found here.
LGLDSR73
89
Boston
Thanks Bowser but the pool is only going to be up for another 3 weeks and 4 gallons will be overkill (~5,000 gal). Before I found this fantastic Forum I was using pool shock so in between last year and early this year I have eight gallons of that to get rid of when the landfill has a Hazmat day.
Best,
Skip
LGLDSR73
89
Boston
Exactly, and I'd like to use Bleach. Any specific brands? I never knew about polymers, thanks for the heads up.
Best,
Skip
Demegrad9
362
Coventry, CT
There are a few Ocean State Job Lots stores around Boston. They stock 12% 'Liquid Shock' around me for ~$3/gallon. It's the same as bleach, just more concentrated so you have to use less.
rocker93
20
Great Lakes
If you're still stuck, I "second" the Lowe's suggestion if you have one near you. My Wal-Mart cleared all the Pool Essentials chlorine to make room for back to school stuff, but fortunately yesterday I found the very same Pool Essentials liquid at our Lowe's.
LGLDSR73
89
Boston
Hi Rocker93,
Lowes is where I have been buying it they are all out, despite what their online inventory says......
Thanks!
Skip
