Liner rip
Hey MK. It should be easy peasy. Search for patch kits, there are many threads on the matter. Basically you’ll cut a patch a little bigger than the cut and then use an even bigger patch to patch the patch. You will need a helper or a weighted backpack to hold you down. Either way you need someone to watch for safety. Shallow water blackout is a thing so no hyperventilating or trying cockamamie ways to hold your breath longer.
Reactions: Mkstretch
