Got a 18x32 above ground pool last year with a SWG and sand filter. Decided not to drain it over winter, but my cover kept coming off and dumped a ton of leaves in the pool. I uncovered it a week ago and couldn't see the bottom it was so dark. Pulled probably 50+ leaf skimmers full of leaves out, been vacuuming and brushing (side walls were green and slimy film). It had no CYA and my SWG says 2800 ppm salt (3200 to end last year, but added 8" or so of new water due to frequent backwashes). After several days of this (and SLAMing to 10 FC per the instructions), I could finally see the bottom, vacuumed the remaining leaves and thought I'd be done in another day. Added some CYA to not lose any FC. I then ran other tests and found the below:
FC 19.0
CYA 60
CC 0
Ph 7.4
TA 110
The sides are no longer slimy, but there's still a pretty substantial green tint to the water. I ran a OCLT and it dropped from 19.0 to 17.0. After adding CYA and testing it as 60, I bumped up my FC to 24 (per SLAM) and it's been like that for 3 days, with no real improvement in the water clarity or green tint. I still vacuum and backwash the filter daily, but it's not really getting better. Ideas?
FC 19.0
CYA 60
CC 0
Ph 7.4
TA 110
