Leaking pump
Not sure if you can see the leak from this picture. It’s hard to capture. But it just spits a little water out then stops. But it’s reoccurring about every 30 seconds.
You really shouldn't have any water leaking, certainly not from the pump motor itself. Water is tricky though and can leak from one spot but run further away to a different location. Since you mentioned "spitting", hopefully it's just something simple. If your pump has hoses connected by fittings, check those. Also check under the clear lid to the pump pot. There's an O-ring under there that should have a decent amount of pool silicone lube to keep it sealed. Never use petroleum jelly on pool rubber seals.
If later you believe the leak to be coming from within the pump casing, you should call the company as it should be under warranty. Good luck!
Okay so I feel a bit silly now. It was condensation gathering to one spot and dripping. It rained overnight and was very humid this morning. Now that the sun is out and the sweat all dried up it’s not doing it anymore lol. Thank you.
