Reviewed the TFP FAQ for finding leaks and after some research looking for suggested next steps:
-Did bucket measure to verify water loss over 1 week period: Pool lost 4.5 inches of water over the week (this is above and beyond evaporation).
-Over the week I ran the pump 12 hours on/12 hours off
-80% of the 4.5 inch loss occurred during the 12 hours the pump was OFF, 20% of the loss occurred while the pump was ON
-Using the TFP guide I checked all items on the equipment pad for any leaks at connections. air loss, lubed o-ring on pump...all items mentioned in the guide: I'm 99.9% sure no leak at pad
-Turned off pump and carefully checked inside the pool using a leak dye for any leaks in the lining, around light, returns, skimmer, main drain and vinyl overlaps. Found no leaks but it's a large area so can only say ~80% sure no leaks in the pool itself
From that background it seems most likely the main culprit for the water loss in 1 of the 2 suction side lines -does that sound reasonable? If so would you suggest next step be a pressure test of the suction lines (main drain and side skimmer)? Then assuming pressure test revels a line w/ a leak how is that best rectified? Run a new line?
Thanks
Thanks
