HI,
Looking for any suggestions ....
I noticed that I have been loosing about 3/4 of ware overnight from the pool.
I think I have a leak somewhere between my skimmer and the pool pump.
- I plugged the return lines and kept the line from the skimmer unplugged and pool lost almost 3/4 inch overnight
- I plugged the skimmer line and kept the return lines open and lost no water overnight
- I then dug up along the skimmer line to the pump at all the "joints" that connect the PVC pipes to the pump and saw no leaks at the joints ( checked with pump running and pump off)
- I then dug around the skimmer and located the pipe coming from the skimmer and saw no leaks (its a copper pipe that comes out horizontally out of some concrete)
- there is no air in the pump basket when the pump is on
Is it possible to have a leak in the line and have no air bubbles in the pump basket?
I am confused as to where this leak could be. If there is a crack along the pipe from the skimmer to the pump, wouldn't there be air bubbles in the pump basket?
Thanks for any help or suggestions.
