We have a major leak in our pool. The concrete deck at one end has raised about 1/2" above where it used to be. I believe this has caused the drain pipe in the skimmer to separate from the joint. I can't see it, but it feels like there is a gap in the plumbing.
My first question is, can I safely turn off the skimmer line at the equipment and run the pump with the main drains only? That way I can stop adding water daily and let the level drop below the skimmers until I can get it repaired.
Second question, does anyone in the DFW area know of someone that can fix this?
Thanks.
Thanks.
