Is it safe to say that if I were to pass an OCLT right now that it would be alright to swim in even though it's cloudy?
Using the Taylor Watergram wheel, when I hold the 500 CH at 90 TA, and turn the arrow to 7.4 for pH, the saturation index reads 0.1 for 78* water....I just measured the temp. at 77.5...From what Im reading on the back, it says SI of .5 or greater could cause cloudiness.
I think we may start a water replacement tomorrow to get the hardness down....the CH of our softened well water is 25.
My bad... I entered your TA wrong into the pool calc. Even with CH that high, your SI is still within range. As long as you swear off the cal-hypo shock and tabs, you should be fine. If you still want to replace some of the water, keep an eye on your CYA level especially if it's going to be a sunny week, but make sure you consult with the senior members here before you add anything.
I think you're just going to need to keep SLAMing. Since you have a sand filter, DE should help expedite the filtering process immensely.
I'd stay away from the clarifier - it's just adding another variable into the equation. It's not necessary, and people seem to have mixed results when using it.
