I have a Pentair Intelliflo which is just a little over 5 years old. A recent problem is that it is losing track of the time overnight and not starting up in the morning. It is connected to a Pentair Compool LX-100 power box from 2006 which used to power a single speed pump. When the variable speed pump was installed it was programmed to go on/off at the same time as the mechanical clock. This way salt cell and everything else powered off at night.
From what I have read, it's probably a capacitor in the pump which is no longer saving the time when powered off. Short term solution is to just have the LX-100 clock on 24/7 so the pump doesn't lose power. What I would really like to do is wire the pump up so that it is powered 24/7 even when the mechanical clock is off.
Is this possible with the LX-100? I'm pretty handy and have done electrical work but trying to understand if I need a new circuit or if I can open up the LX-100 and re-wire the pump. I did not find much documentation on the electrical side which is why I am seeking advice.
Thanks.
Thanks.
