Hi everyone,
I'm an amateur pool owner and haven't done much in terms of taking care of my pool, I'm seeking help in developing my post shock plan of attack in making the pool swimmable
Long story short
- Pool was super green
- Shocked and now it's cloudy blue and will clear over the next few days
- As a result of shocking, Free and Total Chlorine is very high, Ph and Alkalinity is very high
Things I also know
- CYA is virtually 0
- Salt is virtually 0 (Salt water Generator Pool
- 40,000L Pool
I'm just wondering what steps I need to do to make this pool swimmable
Should I let the Sun kill off some of the free and total chlorine to normal levels and then increase CYA, then reduce Ph and Alkalinity levels within normal range then finish with Salt?
Should I add Salt first to normal levels, so Chlorine can be generated, then let the Sun kill off some of the free and total chlorine to lower levels and have the generator balance chlorine, then add CYA, reduce Ph and Alkalinity and then add Salt
I'm unsure what are the next steps from this point onwards in my plan of attack of making this pool swimmable again
Hope this post wasn't too long and thank you in advanced for any help
Long story short
Things I also know
- 40,000L Pool
