Thanks everyone.......I'm going to try to drain and refill tonight/tomorrow so maybe I will be able to enjoy a nice clean "balanced" pool tomorrow night or Sunday
I use a self contained mini-vac similar to this one. I think of it as a DustBuster and my Polaris as a Roomba.One more question. While the water level is really low any suggestios on getting really little debris out before I start filling it back up? Earlier while it was draining I got most of the leaves and bigger things I could but it seems there's still some amount of dirt/sand that I can see on the bottom....any suggestios?
Use muriatic acid to lower pH to 7.2. Add chlorine. Maintain it at SLAM level every couple hours.
You can get muriatic acid at Home Depot, Lowes, Ace, paint stores, pool stores.
You can use plain bleach. Better is 10% liquid chlorine from Walmart, Home Depot, Lowes, some pool stores.
SLAM -- Shock Level and Maintain. You Maintain until you pass the three criteria. Read SLAM Process
Please read Trouble Free Pool School.
After you use PoolMath to determine how much Muriatic Acid (MA) you need, then SLOWLY pour that in the pool right in front of the return jet so it gets diluted real fast. Give the pool floor a light brushing to "stir" any acid that sank to the bottom before dilluting completely. When pouring MA, avoid getting it on yourself, minimize splashing, don't submerge bottle, and avoid breathing the fumes. More safety information on the bottle. Not nuclear waste or anything, but does demand your full attention and respect.
Then wait 20-30 minutes after you finish brushing the floor and retest PH only to verify.
If 6.8-7.2 - you did it! go ahead and add the bleach.
If you are still higher than 7.2, plug the new PH into PoolMath with your previous TA and see how much more acid to add to get to 7.2. slow pour, stir, wait, retest
If lower than 6.8 - let us know and tell us how much MA you added.
Please note - we always space MA and bleach 20-30 minutes apart, never add both at the same time, even with pump on.
So if I'm understanding this right it could take all day to do this. Correct? If so I'm thinking it's going to have to wait til next weekend to do it
You can check pH after 20-30 minutes of adding the muriatic acid if it was added into the return jet stream, and the pump was left running. Even if you had to check it three times that’s less than 90 minutes, far from all day.
