We used leuders limestone for our pool coping. I live in Texas where it can get to 105 for months with no rain. 4 months after our pool completion, our limestone started spalling. At that time we had freezing temps, which causes spalling. At this time I had a chlorine puck pool. After...
The point of referencing the other post was to point out that there are different qualities of stone and that a really good stone can hold up where a cheap stone will fall apart.
You need to have the stone supplier provide a document with the specs of the stone so that you can evaluate the stone on objective facts.
For example, this stone looks like it is really good if the numbers are accurate.
ASTM International (formerly the American Society for Testing and Materials) classifies limestone in three categories:
Class I (Light Duty): Soft limestone best used for dimensional pieces and carving. Most buildings in Paris use these types of stone.
Class II (Medium Duty): These stones can be used in thin cladding and residential flooring as well as bath applications.
Class III (Heavy Duty): The French call these limestones “Pierres Marbrières,” or literally, marble-like limestones. Comparable in hardness and porosity to harder marbles, these stones can be used in heavy commercial traffic applications and countertops.
A good example of how the correct stone was chosen for the corresponding building application is Le Louvre in Paris. While the original building was built with soft limestone, Saint Maximim, the new interior extension is cladded in a medium duty stone, Magny Doré. Also, the new interior flooring is a heavy duty limestone from the Chassagne quarry in France and able to withstand the foot traffic of 8 million visitors a year.
Calacatta is the most sought after material in the natural stone universe. Calacatta and Carrara marble are very different, learn why.
ariastonegallery.com
Also, just because a product is well known for being great, the product might be average with a really good marketing department.
Is Carrara marble really worth the premium over other no-name marble or does it just have a bunch of hype?
For any stone that has a name, you have to be extra careful to deal with a reputable seller.
You also have to get the actual specs to verify which type of stone quality the stone really is.
However, you cannot always be sure that the spec sheet actually goes with the stone that is actually delivered unless you have your own expert check the stone and even quality test it.
We have a very good stone yard here. There has been this Jerusalem limestone put in and around many pool in our area with no ill affects. We found out today, so that’s what we are putting in! Hyped up
