- Jul 9, 2022
- 24
- Plaster
- Jandy Aquapure 1400
Fellow TFPer’s,
We have a Jandy ePump VSSHP270DV2A that was installed Sep 2022 by a Jandy authorized installer. It seems to be much louder than I remember post install and I think it’s happened gradually over time. It did happen suddenly once before and the cause was a dead lizard jammed in the cooling fan area. I figured at this point it was the same and honestly hadn’t noticed it until the neighbors said it seemed louder. I took off the cover for the cooling fan and all I could find was more debris than usual (recently completed landscape project where they brought in sand/soil to bring up elevation after a drainage project. I fear maybe they slung it around the fan and it was ingested since it seems to coincide with when the neighbors mentioned it. Cleaned it off but the sound remains…is this a normal sound for this pump? I have a pending warranty request with Jandy for someone to come take a look. Any ideas are much appreciated!
-One video is 1250 RPM (usually run low speed at 1750 to keep some skimming action….our yard is a perimeter of bamboo and the leaves are constant) and the other is 2750 RPM
-impeller is clear, we use skimming baskets with hair nets…the only thing I haven’t checked is the cartridges (been about 3 months since I’ve cleaned them but no rise in filter psi right now)
