Hi.
I have a Jandy True Clear system added to my automation system. The tech configured the aquapure settings on the iaqualink to provide 60% for Pool and 5% for Spa. We don't see anything else on the TrueClear display. Only says Standby 0% and if you press the power button it flip between that and JandyAutomation.. So not sure if it is actually working or not. Any ideas? The Pool Tech is going to call for another crew to check on it as he is not sure on the automation piece as when that is enable you can't manage the true clear with the front panel buttons it seems.
When checking Status on iAqualink I have:
Filter Pump
Jandy ePUMP 1
RPM: 2250
Watts: 463
AquaPure 0%
Salt 3000 PPM
This is a new pool so no clue on what to check next until the warranty crew from the PB comes in a week or two.
Any idea?
-embeleco
Filter Pump
Jandy ePUMP 1
RPM: 2250
Watts: 463
AquaPure 0%
Salt 3000 PPM
Any idea?
-embeleco
