Here in North Texas, salt water pool, we’ve had quite the heat stretch the last month over 100
Each day, and our pool constantly gets 11-12 hours of direct sun a day. I’m having to run the SWG at 100% lately just to even TRY to keep up, typically I would be running the pump 8 1/2 hours a day (18,000) gallons, I’ve recently bumped it up to 13. FC is barely visible, and noticed an algae spot or two last week. Supplement with liquid chlorine? Water temps are 92-94 in the heat of the day. I assume it’s just burning off so fast than the pump can make it. I do use a Taylor test kit.
CYA - 80
PH - 7.6
TA - 100
Calcium -400
Salt - 3200
CYA - 80
PH - 7.6
TA - 100
Calcium -400
Salt - 3200
