I would just like to start with a big thanks to the community. FOr a new pool owner this has been a great resource of information.
I have a raypak 266 natural gas heater for my pool, I believe it's a copper exchanger. I have an aquarite low salt system running at 1700-1800 ppm salt.
Most recent test results ( using TFT)
ph 7.8
CH 200
salt 1800
TA - 100
Cya 60
Free chlorine 8
CC 0
The pool was only open for a month last year after installation before being closed. It was not really used due to it being october at the time. I'm sure the water chemistry was terrible for at least 3 out of those 4 weeks before I balanced it before closing. I took the sample to a store twice now to verify the results of TC which was around 0.2-0.3 ppm over the 3 tests.
I have a few questions regarding this. Should I be worried about this or this setup? I am not sure if this is as a result of my poor water chemistry for those 3 weeks last year. If so, moving forward with my chemistry in check should this stay under control? I do have a sand filter so with backwashing and fresh water I'm hoping this would go down over time or at least not rise. My other concern is with a SWG is it still ok to use copper heat exchangers or should I consider upgrading the heater to one with a different heat exchanger? Lastly I have read (and not sure how accurate this is) that flow and high chlorine levels can increase the corrosion of the copper. If that is true, how high chlorine levels are we talking about? In terms of flow, how much flow would be too much? Current plumbing is all 1.5 inch, however I do have a flow meter and with my VS pump my flows are running around 45-50 gpm at the maximum ( usually 5 hours a day) and 20-30 gpm the rest of the day), SWG flow always active, though output at 50-70% usually.
ph 7.8
CH 200
salt 1800
TA - 100
Cya 60
Free chlorine 8
CC 0
