Thanks. I was reading about Jacks and the first thing it said was it can only be done if bypassing the heater. I have a heater for the spa and no bypass.You can also use Jack's # 2 copper and scale stuff, but that is sulfamic acid and it will lock up the chlorine for months.
It's manageable, but it takes a lot of time and effort to manage the FC with sulfamic acid in the water.
Below, you can see actual pictures of the sulfamic acid molecule and the chlorosulfamate ion.
_____________________________________________________________________________________________________________________
These work. Feeds directly from the jug of acid. Just keep it moving.Has anyone used either of these tools?
