I have an old PCB 8124A (Assembly 8125G) which I wanted to keep as backup when my new iAqualink PCB needs to be fixed (this way I can keep my pump running). I have a Jandy VS Flopro with no display - aka the pump can only be programmed via the App or via my Jandy One Touch. Can the older PCB 8124A be used to control my VS Flopro?
If it cannot, which PCB board can I use? The Jandy VS FloPro manual says Rev O or above, but I do not know which model has which Rev. This is just a backup so I do not need anything fancy. Thanks!
