I have a cracked 3-way Jandy diverter valve that needs to be replaced. It is cracked on the bottom and leaks water when I turn the pump on. I watched a video on youtube and it looks like I just need to saw off the white pipes and attach straight connectors and another short pipe when placing a new 3-way diverter valve. However, I am stuck on what to do about the side where the Ortega valve is connected. There also appears to be a check valve under the Ortega valve. If I remember correctly, in the past my pool guy wasn’t able to find parts for the Ortega valve, so he redid the plumbing and replaced it with a Jandy check valve. So it appears that the Ortega valve may possibly be serving as a connector pipe. My questions are:
1. What size Jandy 3-way diverter valve do I need to get?
2. When I replace the 3-way diverter valve, would I need to saw off a portion of the Ortega valve or completely replace it with another Ortega valve?
3. It may be hard to find another Ortega valve, if I cannot find one, what type of valve could I replace my Ortega valve with?
4. If the Ortega valve is serving only as a connecting pipe, would I just need to replace it with connectors and short pipes to connect the diverter valve to the check valve?
I have included 3 photos showing the below:
- Before the check valve was installed under the Ortega valve
- Diagram labeling the parts
- Zoomed out view of the pump system for reference
