i have a jandy lxi 400p pool heater from roughly 2008 that will not start.
the history is that this heater did not work when i attempted to use it about 1.5 years ago, so i figured out that the low voltage cable connecting it to the aqualink rs control system was bad. after replacing and reterminating the wires for this connection, the heater worked for the next ~6 months. the heater is refusing to start again, presumably for different reasons that the first time because i've confirmed the low voltage connection between the controller and the heater is live.
i've searched the forum quite a bit to self-educate and found the extremely helpful wiki entry for jandy lxi heaters. from this page, i followed it to the jandy troubleshooting guide with the wiring diagram for the lxi heater series. i have followed these instructions and checked the first few steps, but i have found that at step 5 (page 6) that if i don't see 24 vac between the water pressure switch line and ground, it says
"Do a Back Pressure Test, if pressure is higher than 2 PSI, replace Water Pressure Switch, if less clean filter, baskets or repair pressure problem"
i'm guessing i have a bad water pressure switch, but i would like to confirm that before ordering a replacement part. i couldn't find documentation on how to perform a back pressure test and have no idea how involved this is.
input appreciated, thanks for reading!
