- May 17, 2019
- 403
- Plaster
- Pentair Intellichlor IC-60
What times does your pump run?I schedule my heater to be on from 9AM to 9PM. I don't want it running all night. The heater usually runs for a bit in the morning to restore any heat lost overnight and get the pool back to the temperature setpoint.
Higher rpm when the heater comes on?24 hours a day at 1700 rpm.
Higher rpm when the heater comes on?![]()
What temp do you keep heater at?
What's your IC60 set at to be able to run the pump 24 hours a day?
Does your spa spillover stay on all the time?
How do you like your plaster? We will be refinishing early next spring most likely.
Ugh. Now my iAqualink has a red dot and won't connect to the app.
edit: and fixed.
So they did not use the 4 wire. One 4 wire port was used for the iq-20 upgrade. The other was used for both the VSF Pentair pump and the old pda controller for the box. It’s a bit odd. The heater is on a 2 wire.
I thought so too, but a wire was loose in the iAquaLink box so i adjusted and it fixed it. I realized it because my pump wasn’t showing automation mode on the digital screen.There is a bug in the app. When it does that, usually all you need to do is swipe down to refresh the screen and it reconnects.
Interesting. I’ll have to play with having 2 temps. Does it allow you to select from them from them on the quick app screen?See below I have 2 temperature set points. Temp1 and Temp2. My pump runs 24x7 at 2k rpms. It automatically increases to 3k when heat is called for. I use my heater "on demand". When I need it, I run it. When I am going to swim, I turn it on with enough lead time to get up to temp. During the summer it doesn't usually drop much below 90 even without heat but on colder night or coming into shoulder months it needs help. I typically don't run it at night for any reason though.
With your pump at full speed, what is your filter pressure? Mine never goes much above 22 or so.
Nice! Where do you put that new board? Is there a tutorial you followed? I’m not very handy with electrical ...You can get the below if you need more devices. You don't need to connect the heater via 4-wire. It is sloppy, but not required. My electrician did the same thing. I went back in myself and re-wired for the 4-wire connection.
Amazon.com: Zodiac 6584 Multiplex Printed Circuit Board Replacement Kit for Zodiac Jandy AquaLink RS Pool and Spa Control System: Garden & Outdoor
Amazon.com: Zodiac 6584 Multiplex Printed Circuit Board Replacement Kit for Zodiac Jandy AquaLink RS Pool and Spa Control System: Garden & Outdoorwww.amazon.com
At full speed with heater on probably over 30 psi but I’ll check later. What’s max speed on the VSF? 3600rpm?
with heater off it’s probably lower (the Versaflo bypasses the heater).
Interesting that both of you northeast guys run your pumps all night. I’m not used to thinking that way given my previous pump was single speed.
thanks. this is gibberish to me, though. hahThere are multiple ways to control pump speed for variable speed pumps In addition to traditional automation systems. one way is to make use of digital inputs. Some pumps have this capability built in and some require an adapter. If you use digital inputs you can change pump speed with signals that are generated by various different pieces of equipment. For example if you want to change the pump speed to increase it when the solar valve is closed which allows water to flow to the roof you can take the same signal that closes the valve and wire that to one of the digital inputs and then set that input to the desired speed. In your case you could do what I have done for my heater which is to take the signal from the gas valve and add a wire that goes to the digital input just to increase speed to the gas heater requirement. All of the pumps and adapters seem to use the same or very similar electronics. This signal can be anywhere from 12 to 30 volts and it can be AC or DC. So virtually any signal that is used by your equipment will be compatible with the digital input requirements.
I hope this is helpful.
Chris
I meant this on the app before going to the web. I’m going to play with the multiple temps.Having the pump on all night is for chlorine production. It is easier to calculate what a pool needs with a constant like the SWG being on all the time. Mine is dialed in at 53% with the pump running 24x7. I have never had a single spec of algae in my pool.
You mean the OneTouch?
There are also other temp related settings in your Aqualink setup.
You also have an "all off" function that turns everything off at a set time "just in case" someone left something on. So for instance, you could set this at 12am and then at 12:05am, turn on your pump for SWG chlorine production.
