- Oct 25, 2015
- 5,200
- Plaster
- CircuPool RJ-60 Plus
15,
I think that's a question for your gas company. But you may not need one. Just add up the max heat and gas consumption to see how close you'll be. Also note meters are rated at .5" WC drop that is not the max you can use. At 2" drop you can get over 2000 cu ft per hr. This should leave you with 10" at the discharge and should be adequate unless you have very long runs of small diameter pipe. If it were me I'd just manage the pool as the lowest priority. Seems like it will be pretty rare you do max on everything and in that case the pool isn't likely to be needed. Also you can always do a load test. Just crank everything up at once (make sure the genset is under load not just idling). Then start the heater and see what happens. I do a full load test on my genset every year at the beginning of hurricane season by opening the main disconnect at the meter.
Chris
Chris
