I just acquired a home with a pool and a spa. The prior owner manually controlled everything and I wanted to convert to remote operation. I'm able to switch between pool and spa modes on the Jandy RS controller as desired, no porblem there. The issue I'm having is either the capability of the Jandy unit or how it's been connected to the Raypak heater. The instructions on the Raypak allow for a 2-wire remote control (for a single function, heating of a Pool OR Spa) or a 3-Wire control (for the heating of a Pool AND Spa). My logic tells me that the control I need is the 3-wire since I want to independently control the temp of both the Pool and the Spa. However, the Jandy unit only has a 2-wire connection for the heater. The Jandy manual provides instructions for a 2-wire connection, but doesn't mention 3-wire at all.
Can this Jandy controller control both pool and spa heating or is it limited to one function? If it can control the heating of both the pool AND the Spa, how do you correctly setup the unit? Two pics for your info, first is of the Raypak control board and the second is for the Jandy. Both illustrate the actual connections/wiring.
Here you see the the following wiring:
Raypak Blue (24vAC) to Green and Yellow on Jandy 9 connector
Raypak Black/Orange (Pool Common) to Red and Black on Jandy 10 connector
Raypak Orange/Black (Spa Common) to Nothing.
What do I need to do to make this work?
Many thanks in advance.
Alex
Note: this is not same the system that's described inn my signature.
Alex
