- May 31, 2012
- 854
- Vinyl
- Jandy Aquapure 1400
Each year after my pool is opened the salt level is low as the salt concentration gets diluted bu additional water in the winter. Using the Taylor salt test kit my initial level was 2400. I added 100kg of salt and now read a level of 3200. My Jandy Aquapure 1400 has a salinity measure and it reads 1.9 (which I believe is the same as 2000 ppm). This causes the service light to come on with error 144 - salt level low. I am wondering if this reading could be caused by low water temperatures as I haven't started heating my pool yet and the temperature is currently about 55F. Anyone know if the low temperature will cause issues with the sensor? I am guessing that I should trust my Taylor kit more than the sensor, correct?
