Jandy Aqualink wiring help
emmaschwartz
6
Fort Worth, Texas
Can someone please help me understand what each of these do? We need a new swg and maybe pump and want to do the install ourselves if possible. We also replaced the pool lights a year or two ago (my dad did this) and now the light doesn't work so it must be wired incorrectly.
Filter Pump button definitely turns on the filter pump, Aux 1 turns on polaris vacuum, Aux 2 turns on the tall thing and make the spa bubble, Aux 3 made a jandy actuator valve move, Aux 4 made a clicking noise but I couldn't determine if anything else happened, Aux 5,6,7 make no noise. I do have more pictures if needed.
We can't guess where unlabeled wires go to or what they do any more than you can. Each wire and conduit needs to be followed to see what device it connects to, and then it needs to be labeled.
The things in the Aqualink are explained in...
The AquaPure SWG is explained in...
Your Aqualink RS ability to control a modern VS pump will depend on it's Rev Version. You need at least Rev O to control VS pumps.
