- Jul 21, 2013
- 65,758
- Plaster
- Pentair Intellichlor IC-60
On “RETURN” :
In SPA FILL MODE
Red and black: 27
Red and white: 3.9
In POOL MODE
red and black: 27
Red and white: 3.
I got a spark and now the whole thing turned off. Mistakenly had my lead touch red and black at the same time. You warned me. I tried switching the breaker from on to off and back to on but nothing. Is it toast?See what you get on the SUCTION socket for the same test.
INTAKE
SPA MODE:
Black and red: 1.5
Red and white: 2.7
AUTOWhy are you going into SERVICE mode?
Stay in AUTO and toggle SPA on or off
To clarify,
When I switch between Pool mode and Spa Mode only the INTAKE actuator functions. The RETURN actuator has no response.
when I plug the RETURN actuator into the INTAKE connector, the RETURN actuator acts as expected and cycles properly from Pool mode and Spa mode.
When I plug the INTAKE actuator into the RETURN connect, the INTAKE actuator does not move.
Thanks for sending the link.Do you have iAqualink?
If not, you should get the iAqualink IQ30-RS upgrade which gives you a new board and the iAqualink Wifi antenna.
And the Leslie link says it has Rev QQ. You want the latest firmware which I think is Y or Yg.
Jandy iAquaLink 3.0 Web Connect Device
#IQ30-RS iAquaLink Web Connect Device Kitwww.tcpoolequipment.com
Yes, the latest version will work with your All Button Control Panel. Although any new features, and there are many in the latest version, may not be accessible from your old control panel.Thanks for sending the link.
Will it still be compatible with my console in the house. Pictured below.
I think the pool was built around 2000.Yes, the latest version will work with your All Button Control Panel. Although any new features, and there are many in the latest version, may not be accessible from your old control panel.
What Rev level is your current board?
Read Jandy Aqualink RS - Further Reading
