My Jandy actuator is not working as it was before. Normally, if I wanted to run the cleaner (suction side cleaner) I simply click that button (assigned auxiliary) and it would move the valve and the pump would turn on (same with my waterfall). Now, the valve will move, for example, I click the cleaner, the valve engages, but the pump won't kick on. Of course, I can manually turn on the pump and it will work as it is supposed to. Same with the waterfall--I have to (now) press both the assigned auxiliary button and the pump button to get them to go on. Also, it seems the valve isn't returning to the original position. I ran a diagnostic test, and I saw the valves moving, but I did notice the one valve didn't move back. Since the test moves through the cycle very fast, it didn't allow enough time for the valve to complete the cycle--but one valve just stayed in that position (only moved an inch--so neither fully open or closed--and it didn't return to the start position). Any ideas?
I have a Pentair system.
