Water coming out in a stream from back of JANDY 3 WAY VALVE when tuned to any 90 DEGREE position
EVOMAN
1
PORT ST. JOHN FLORIDA
I have a JANDY 3 WAY VALVE that when turned to any 90 degree position squirts a stream of wate r when turned to these positions. Once i turn it so all water inlets are in a (T Position valve stops spraying stream of water. What is this hole on back with rubber grommet or bushing for? All help appreciatted.:cool:
The NeverLube valves have a lifetime warranty, the grey valves do not.
The grease fitting probably broke off and you can use a 1/8" npt plug to plug the hole once you remove the grease fitting part.
