- Apr 5, 2022
- 95
- Vinyl
- Hayward Aqua Rite (T-15)
So I have a pentair Rainbow Chlorinator 320 installed last year. I love it. Last year, I would put in 3-4 chlorine tablets, set the dial to the highest setting (which was 5), wait for it to fill up once I turned the pump on, close lid, and it worked like a champ. The tablets would last about a week so every Sunday I'd know it was about time to add more tablets. Other than occasional shocking, the pool always stayed within the proper chlorine ranges.
This year, I opened the pool in April and the pool temperature has been mostly 60 degrees. Planned to turn my heater on in May but just wanted it nice and clean and ready to go for when I turn the heater on. It took a few days to have crystal clear water after super shocking and everything has been fine (had an issue where pump was randomly shutting off, but solved that several weeks ago)....except I noticed that the chlorine was barely dissolving in the chlorinator. The same tablets I put in still had at least half life 2 weeks later. I had my pool 24 hours a day at medium speed (1725 rpm) because we aren't using it. In the summer I run it faster at times but since we weren't in it yet I figured that was unnecessary. Thinking maybe the pump just wasn't running fast enough, I thought ok maybe I need to run the pump faster for parts of the day. So I set it a little over a week ago to run it at 1725 for about 18 hours and then for about 2500 rpm for 6 hours a day. I used that all summer last year and it worked out fine. I put 2 more tablets in there so I had 2 half used 3" tabs, and 2 brand new tabs. One week later, I open the chlorinator and they still are mostly unused. Maybe 90% life left on the new tabs, and a little less than half life left on the now 2+ week old tabs. It was filled with water because the water drained when I opened it. I noticed the chlorine levels were low which prompt me to check it.
So I googled a few things and saw how I unscrew the line from the in/outs of it. I did that and cleaned it. It didn't appear to me that anything was clogged or in bad shape there. I removed the black piece at the bottom of the chlorinator and cleaned it good. It looked like it was in adequate shape, also not appearing clogged at all. Then I used my water hose and just sprayed all inside the chlorinator trying to clean everything I could. I then put the other 3 tablets in my actual pool skimmer so they can actually get used up, and left one of the newer ones in the chlorinator to see if maybe whatever I did fixed it. Does anyone have any idea what might be going on and if I should try something else?
A couple of info. It's a 22,000 gallon pool with a hayward heat pump (not turned on yet) and a vsp hayward pump with a waterco pre filter just past the pump as well as a cartridge filter. I confirmed that water is running into the chlorinator after I start the pump before I put the lid on. I let it get full, then I twist the lid on. When I stop the pump, I wait a few minutes, open the chlorinator, and it is still filled with the water. As I open the lid, all the water quickly drains through the bottom of it....seemingly to me showing that it is both receiving water and draining water. Does that seem normal on how it should behave? The only other thing at all that I noticed is if you google any picture of a rainbow chlorinator 320, the "in" line is connected at the bottom of the tower (and the top has a black seal just below the lid). My "in" line is connected at the top of my chlorinator with the black seal being on the bottom. In other words, that tube that comes from the very bottom where the main pool plumbing is, runs to just below the lid, and water shoots in from just below the lid. Is that setup right?
