- Apr 5, 2022
- 95
- Vinyl
- Hayward Aqua Rite (T-15)
I opened my pool a few weeks ago, and it seems like about once a day the pump will turn off. When it turns off, I get no notification, no alarm, no anything. No error codes, it primes just fine, all seems well. I just open the omnilogic app and see that the pump is off. I then have to manually turn it back on and it seems to be fine for another 12-24 hours.
I don't think this happened last year, but I had schedules set up so it would of been easy to miss if it did turn off at points last year. I cleared all my schedules and was just having it run at medium speed until I turn the heater on in May to actually get in it.
Any ideas? The breaker does not shut off, there's no indication that anything else is problematic. It's basically the same as me manually turning it off. System is a little over a year old so it should all be under warranty but I'm thinking this could just be a software related issue and don't want to get pool company/hayward involved if its some sort of setting problem.
I know this makes no sense, but a working theory I'm currently testing is I feel like it stays on really close to 12 hours before it turns off. I deleted all schedules and basically just left it on medium so that I could diagnose. It was correctly reading the correct time and am/pm but not sure if I have DST on or not. Not sure if it matters. I did update it to the newest version (4.3.2 I believe) thinking that may fix it....it did not.
