- Feb 11, 2022
- 8
- Plaster
- Pentair Intellichlor IC-40
What is a good schedule to run the filter pump?
10,850 gallons, gunite, Pentair IntelliFlo VS 3050, Polaris 280 cleaner (which comes with a 3/4 HP booster pump but I'm honestly confused about what it does, as the cleaner seems to run only off the main pump).
The PB set it at 3450 RPMs for 8 hours. I changed it later to 3000 RPMs (around 70 GPM) for 12 hours. I know it's still too much probably, but I don't mind. Ideally I guess I'd prefer to run it at 3000 for 6-8 hours (with cleaner) and another 2-4 hours at 2000 RPMs or so (without cleaner). Would that make sense?
PB told me it needs to run at a minimum of XXXX RPMs (I forgot the number he gave me) for "things to work properly" (I don't remember whether he was referring to the cleaner or the SWG?).
I'm happy to run it more than required, without being recklessly excessive. Also, in terms of electricity cost, there is no difference between day and night. Lastly, do the RPMs influence chlorine production? Or is that simply a question of the filter running, regardless of speed?
Thanks much in advance for any pointers.
