I want to know if there is an automation system that is capable of reducing the speed of the pump after the solar speed is activated. The reason why I want this option is when solar demand turns on, the pump needs to run at a high RPM to make sure the panels on my roof are fully primed, but once primed the optimal speed can be reduced. An example would be to run the pump at 3000 RPM when solar starts for about five minutes and then reduce the speed to 1700 RPM for the remaining time that the solar is running. If solar is not running then I would like to run the pump around 1000 RPM.
I don't want to use set times to change the speeds as I do that now with my mechanical timers and 2-speed pump.
