There is no doubt my filter & cleaner pool pumps are both leaking copiously at the inlet as shown below (mostly when the pumps are off):
They've been leaking from this very same spot for years:
The problem is that the plumbing is pressed fitting to fitting, with 7 Jandy valves all pressed together, within a foot with nary a pipe in between:
Up until now, I've been trying the "miracle in a tube" solution - but it's really not working to plug and glue and stop up the leak.
QUESTION:
Q: Is there a magic fitting that I can slip into the inlet that will allow me to fix this incessant leak without having to replace either the pumps or the Jandy valves?
QUESTION:
