I've been looking into switching to a heat pump from propane to heat my in-ground pool and spa. My main motivations for switching are the high cost of propane (delivered, $3+ per gallon) and the generally terrible customer service from propane suppliers in the area.
I've read that having a heat pump with a defrost function (either as an added feature to a heat-only pump or inherent to a heat-cold pump) allows the heater to function in colder temperatures below 50 degrees. What I'm not real sure about is, how *well* a heat pump would actually work in such a case. I can't imagine ever wanting to heat my pool in weather that cold, but we might want to use the spa. Would it actually work heat up my spa to 100 degrees if it's 40 degrees out?
I should also point out that I'm in central FL, and we're below 50 degrees only a few days a year, if that.
At this point, I'm thinking in my case that a defrost function isn't worth the extra expense. I also have no use for a cooling function as my pool is in a screen cage which prevents it from ever getting too hot.
Would love some feedback from the more experienced to confirm that suspicion or point out something I'm missing. Thanks!
