Thanks for that Flying Tivo! I've been looking for something like that and will check it out.You can use a stenner pump for liquid chlorine dispensing.
Stenner Pumps - Further Reading
www.troublefreepool.com
If it were only that easy ("stop drinking the pool water"). It's a childhood thing that I have to respect. We did spend time in a SWG pool in Florida last winter and she seemed OK. Maybe there's a opening for another run at it.You may want to check the actual salt level of the pool. You will be surprised at the salt level.
Adding chlorine (in any form) and/or muriatic acid will result in the salt level increasing.
What is her sensitivity?
If it's the ability to taste it, tell her to stop drinking the pool water.
Appreciate that point of view gingrbredman! I'm learning and evolving. I'll stop the algaecide and trust the guidance of this community. Already commented that I'll finish the year with pucks then start liquid next season, maybe with a Stenner pump.Sounds a little like you are mixing protocols. Some TFP, some pool store, some convenience. A truly TFP will not require a drain/refill because CYA or CH gets out of control.
Maybe exposure to other SWG pools would help. Of course, no mention that they are SWG before using, only after.If it were only that easy ("stop drinking the pool water"). It's a childhood thing that I have to respect. We did spend time in a SWG pool in Florida last winter and she seemed OK. Maybe there's a opening for another run at it.
My CYA levels are usually low at the end of the summer so I chlorinate with pucks over through the winter. Don't worry about using your chemicals in a first in, first out situation. Pucks will last a long time in a dry bucket.Appreciate that point of view gingrbredman! I'm learning and evolving. I'll stop the algaecide and trust the guidance of this community. Already commented that I'll finish the year with pucks then start liquid next season, maybe with a Stenner pump.
