- Nov 30, 2019
- 855
- Fiberglass
- Hayward Aqua Rite (T-15)
I have stains which I tested using the Jack’s Stain Identification kit. Application of Jack’s Stain Solution #2 followed by Jack’s Stain Solution #1 (‘Step 6’ of the identification procedure) lifted the stain completely where applied indicating iron although strangely I didn’t see any result when I tested with crushed vitamin C tablets.Curious, is there a specific reason you are wanting to test for iron? Are you seeing staining or water discoloration? Are you on a well?
You can. Though the AA will also consume the FC. So up to you.Can I use sodium thiosulfate and muriatic acid to lower the FC and PH for the Jack’s Magic iron treatment?
